Spark plugs/wires for stock 94z
Old Apr 5, 2007 | 01:01 PM
  #16
bombebomb's Avatar
Originally Posted by Desutterz28
not to sound stupid but will that ignition module fit your car if its a 94 camaro with the Lt1 engine? it says its for the 96 to 97 camaros, not the 94. just something to check out and i was curious myself.
Good question, I know 96 and 97 were OBDII, ill be ordering these parts before 6pm. (not the ignition module)
Old Apr 5, 2007 | 02:09 PM
  #17
2000GTP's Avatar
I believe the difference is that of a different connection. The 93-95s use a dual connector coil where as the 96-97s use a single connection.
Old Apr 5, 2007 | 02:24 PM
  #18
ttop1986's Avatar
Originally Posted by 2000GTP
Those are what I am using, they are a good plug. Just keep in mind they will require quicker changes as compared to a platinum or iridium plug.
How often should you change these? Thats what I'm running and my gas milage has gown down some. Its been about a year. I bet I'm due for a change huh?
Old Apr 5, 2007 | 03:02 PM
  #19
2000GTP's Avatar
The copper plugs will probably have a life of about 30K. I doubt you would be in need of a plug change so soon, but you could always pull a few and see how they look.
Old Apr 11, 2007 | 01:13 PM
  #20
bombebomb's Avatar
Ok bought plugs/wires/coil. should be here tomarrow
canbaufo
May 25, 2015 12:01 PM
kksi
Feb 16, 2015 06:49 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
stopthatman
Feb 9, 2015 09:00 PM
