Spark Plugs And Wires
Old Dec 24, 2007 | 12:33 AM
DustinMcGowan's Avatar
Hey my name is Dustin and I have a 94 Z28 Camaro with the LT1. I have done alot of work to it. The thing I need to do the most is change the spark plugs and the wires. The wires are purtty explainatory. I take one off put one back on. I have heard alot of storys about changing the pass. side back plug. I heard everything from dropping the pass. side motormount a little to getting a 3/8 swivel head rachet and a taking 3/4 of an inch off of the standared plug socket. I can take my time on this but I dont wont to do alot of things that dont need to be. If I could get some input on this it would be a real help to me. Thanks Guy's!
Old Dec 24, 2007 | 01:44 AM
Tex95Z's Avatar
Hi,
Welcome tho the board!
you may want to edit your signature with your car and any mods you have done to it.
on mine I use a 5/8 plug socket and a 3/4 ratcheting wrench, but I have pacesetter mids. not sure if that will work with stock manifolds though
Old Dec 24, 2007 | 01:51 AM
OneEyedBadger's Avatar
I just did this tonight.
Key is to get your car pretty high off the ground. It took me 30 mins to do the 4-driver side plugs and the front 2-pass side plugs.
However the rear 2-pass side plugs i was pretty much just reaching in blind and ended up squeezing in from the top-side and it took some time to figure out the best way to get to them. But I dont see why you would have to mess w/ the motor mounts
(I have a lift in the pole barn so that helps ALOT)
Old Dec 24, 2007 | 01:48 PM
Thanks for the info you guys really helped alot I think Im ready to take on the job now. THANKS!
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
