spark plugs burning uneven - Pic Included!
Old Sep 26, 2010 | 10:04 PM
ThreeHonks's Avatar
I just got my motor back together and was checking a few things out, decided to pull the plugs and this is what I found:
I have never seen anything like this before. As you can tell it is a DRASTIC difference. Please pay attention to #7 plug as it is soot black.
What could be causing this? The motor (and plugs) only have about 40 miles on them including some WOT pulls.
DETAILS ON MY SETUP:
-heads/cam LT1
-has the LS1 pcm conversion 24x system
-has NGK TR-6 plugs
-has 42lb. green top injectors
-tuned in speed density by Dr. Phil INTIMID8
Old Sep 26, 2010 | 10:07 PM
MikeGyver's Avatar
Is it misfiring? Do a compression test.
Old Sep 26, 2010 | 10:17 PM
ThreeHonks's Avatar
No it is not. Car runs awesome and has great power
Old Sep 27, 2010 | 01:00 AM
MikeGyver's Avatar
I wonder how balanced the AFR is between cylinders. Maybe some injectors are dirty.
Old Sep 27, 2010 | 05:11 AM
Check the vacuum compensation line for the fuel pressure regulator. If the FPR is leaking, it will dump raw fuel into the rear cylinders.
Old Sep 27, 2010 | 06:56 AM
ThreeHonks's Avatar
The injectors were suppossedly flow-matched. I have the flow sheet and it all looks good.
Thanks for responding
I just talked with my tuner and he said that it is possible that the rear injectors are seeing more fuel pressure causing it to dump more fuel. I still have my stock FPR on my car and it has 60k miles on it. Without a doubt, I am going to change this out to a new one. Is a stocker the best or would it be a wise investment to get an adjustable one?
Old Sep 27, 2010 | 09:50 AM
ThreeHonks's Avatar
Could this be caused because I dont have a parallel fuel rail setup? I also have the stock intake, and I have heard it can cause a poor distribution. It has been ported by Ai.
I am thinking it has got to be the FPR. The car is running better than it ever has and idles great and never stumbles
Old Sep 27, 2010 | 09:57 PM
What year is your car? Is it a 93, which has the rails set up for batch fire?
Doesn't make any sense if you have a 94-97, if you have the stock "series" rail configuration. Pressure is highest at #8, drops in the sequence the injectors come off the rails - 6 - 4 - 2 - 1 - 3- -5 - 7. Pressure will be higher on the passenger side, highest at #8. Pressure will be lower on the driver's side, lowest at #7.
The stock FPR is not a problem, unless its leaking. That's what you need to check.
Old Sep 27, 2010 | 10:01 PM
ThreeHonks's Avatar
It is a 96 with the stock fuel rails in series. #7 is the richest by far.
I ordered another new stock FPR and a set of plugs. My tuner also sent me another tune file to try and I will be taking it back to him so he can check things over and do a retune if necessary. It is is HPT Beta, so I need to wait til their support gives me that version so I can upload his new tune.
Do you think this could be tuning related?
Old Sep 27, 2010 | 10:03 PM
Did you take the time to check the vacuum compensation line, or do you not feel that is a possible cause?
Old Sep 27, 2010 | 10:11 PM
ThreeHonks's Avatar
I took that off and it had a SLIGHT smell of fuel ( could have just been the garage from the car being in there all the time and running and just eh exhaust smell too) and it was dry as a bone. No fuel dripping or residue
EDIT: the email my tuner just sent me said to not mess with the FPR just yet and to upload his tune first.
mritter1965
Feb 9, 2015 07:01 PM
Jlo
Feb 3, 2015 09:41 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
