Which Spark Plugs?
Old Apr 5, 2009 | 05:01 PM
JamesZ28's Avatar
Which Spark Plugs?
Well I'm finishing up my new set up pretty soon here and I'm wondering which spark plugs to go with. I'll be running an LE 226/230 cam, LE2 Heads and ported intake manifold, Comp Magnum RR's, 37lbs Injectors, Walboro 255 fuel pump, and everything else is in my sig. I like to run NGK's so what would you reccomend? Thanks!
Old Apr 5, 2009 | 05:11 PM
Bersaglieri's Avatar
I'd ask Lloyd Elliot, but otherwise NGK TR55 or some Autolites always worked well for me.
-Dustin-
Old Apr 5, 2009 | 10:23 PM
I'd go one step colder than stock, with the NGK TR6 or the Autolite 104.
Old Apr 13, 2009 | 08:40 PM
z275plus's Avatar
Another vote for the NGK's tr6.
Old Apr 15, 2009 | 06:49 PM
2nd_chances's Avatar
NGK part #4177 is the TR6 heat range for an LT1
Old Apr 16, 2009 | 01:35 AM
Bad LT1's Avatar
-Dustin-
x2!!!
Old Apr 28, 2009 | 08:21 PM
slp223's Avatar
I like the autolite 104 plus they are cheaper then ngk.
Old Apr 28, 2009 | 08:36 PM
one bad Z28's Avatar
I went with autolite platinum spark plugs when I changed mine.
Old Apr 28, 2009 | 08:43 PM
bw_hunter's Avatar
The rule of thumb is one heat range cooler per hundred additional horsepower. NGK TR6's are one heat range cooler than stock and wil work fine. An equivalent heat range from someone else will work just as well..
Try setting the gap to .035" instead of the stock gap...it'll idle smoother.
Old Apr 29, 2009 | 12:39 AM
AdsoYo's Avatar
+1 for autolite 104
Old Apr 29, 2009 | 01:16 PM
maybe2fast's Avatar
autolite 104
CC503 here
Old Apr 29, 2009 | 01:26 PM
hey01's Avatar
Ngk tr55 ix
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
