Which spark plugs?
Old Nov 7, 2006 | 09:42 PM
69gto96z's Avatar
Which spark plugs?
I am about to do a header swap and was gonna put NGK Tr-5's plugs in. The car is mainly stock right now, but will be seeing a camshaft swap to a comp 306 this winter. Will these plugs be fine on a stock motor? Also, do they come pregapped or do I need to gap em?
Old Nov 7, 2006 | 09:50 PM
OBE1 95Z28's Avatar
The TR-55's come pregapped at the stock 0.50" gap. I believe the TR-5's have a smaller gap. The TR-55's will be fine for your application.
Old Nov 7, 2006 | 09:55 PM
69gto96z's Avatar
I was told by a friend with a cam only LT1 that he runs the TR-5s with no problems at all, thats why I wanted to see if it would be fine to go ahead and install em while I had everything out.
Old Nov 8, 2006 | 07:38 AM
2000GTP's Avatar
Pretty much everyone on here with a bolt-on car is using the TR-55 plugs for their applications.
Old Nov 8, 2006 | 09:20 PM
69gto96z's Avatar
Still wanting to know if TR-5's will be fine on a bolt on car.
Old Nov 8, 2006 | 09:26 PM
MeanGreen97Z's Avatar
I used the autolite 106s... Haven't really driven the car with them in much but it sure does idle smooth and it makes some nice power after installing these longtubes.
Old Nov 8, 2006 | 09:38 PM
Bawls's Avatar
Do you run the AP106's or just the 106's. AP106 is the platinum.
Old Nov 8, 2006 | 09:40 PM
Ya the AP platinums. The car hasn't idled this well since I've owned it, but I also fixed a serious intake leak when I put them in.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
