spark plugs
Old May 10, 2005 | 01:21 PM
flounder564's Avatar
Talking spark plugs
i was wondering if anybody had any links to a a install guide for spark plugs on a 1994 z28
Old May 10, 2005 | 01:23 PM
Got-LT1's Avatar
Re: spark plugs
Don't know of any links, just be ready to spend a long time on it.
Old May 10, 2005 | 03:55 PM
WSUFlyer's Avatar
Re: spark plugs
I'm wonderin the same thing....i got the driverside no problem, front two from up top and bottom two from below. The passenger side on the other hand....looks like I'm taking off the AC compressor and starter to get to them. Does that sound right? Is there an easier way?
Ryan
Old May 10, 2005 | 04:42 PM
Got-LT1's Avatar
Re: spark plugs
honestly, i don't remember how I got the passinger side plugs out with the stock exhaust manifolds on, I have had MAC mid-length headers forever and it makes changing them A LOT easier.
Old May 10, 2005 | 06:27 PM
WSUFlyer's Avatar
Re: spark plugs
Yeah, headers on on the list of upgrades. With high prices on the 4th gen headers though it may be a soon. I got lt for my 3rd gen for $100 and a custom made y-pipe for $75. lol
Ryan
Old May 11, 2005 | 11:12 AM
Cnadian_Camaro's Avatar
Re: spark plugs
I do the change in about 2 and a half hours and remove nothing..... you shouldnt have to remove anything.
Old May 11, 2005 | 12:00 PM
Mystic97Z's Avatar
Re: spark plugs
pull the f*cking engine out, thats about the best way.
Old May 11, 2005 | 12:29 PM
CheshireCat's Avatar
Re: spark plugs
I recently changed the plugs, wires and opti on my 94. If you are only doing plugs, the driver's side is pretty easy. you can get the front 3 on the driver's side from the top fairly easily. The back one on the driver's side is easy to get to from the bottom. The passenger side is more difficult. The front plug is the hardest. Remove the belt and alternator, to give your hand some room. There AIR pipe coming off the exhaust manifold is really in the way, so you will have to work around it which is a real pain. The middle two on the passenger side aren't too bad from the top and the back one on the passenger side can be reached from the bottom without removing the y pipe on a single cat car.
Best advice, allow yourself plenty of time and try not to get angry...
If you ever plan on getting headers, I'd do them now and make this whole process much easier... Mac mids are reported to have great plug access...
Good luck.
Old May 11, 2005 | 02:12 PM
WSUFlyer's Avatar
Re: spark plugs
Well I broke a plug boot on the spark plug side....for some reason they were all VERY tight around the ceremic on the plugs. I went to the local speed parts spot...RamChargers....and bought a set of MSD wires. While I was there asked the guy about changing the plugs, and turns out he had plenty of experience with LT1's.
He told me to take the passenger side wheel off and there is a flap that you can move and use HUGE extensions and get to all the plugs without removing anything. I'll be trying this on Sunday and getting back to the thread.
Ryan
Old May 11, 2005 | 03:02 PM
Carpe Diem's Avatar
Re: spark plugs
that is so close to the truth, it isnt even funny.
Old May 11, 2005 | 03:18 PM
GreenZLT1's Avatar
Re: spark plugs
I got the drivers side plugs out from the bottom, and all of the passenger side ones from the top. I just took the alternator off. The rear plug on the passenger side was a pain. I have small arms and had a hard time... wait a minute.. the whole passenger side was a hard time. lol
Rob
Old May 11, 2005 | 03:22 PM
94Zpower's Avatar
Re: spark plugs
The easiest way for me when I had manifolds was to get them from the bottom and remove the Y pipe, like that it wasnt too bad! actually had more of a hard time passing the wires properly lol,
Now with my Mac headers I can get them all from the top.
Old May 12, 2005 | 06:07 PM
spcearle's Avatar
Re: spark plugs
i must have been lucky on mine....pacesetter lt's and it took me alil over an hour to pull and install plugs from the top with no special tools needed first try
Old May 12, 2005 | 06:55 PM
brandboZ28's Avatar
Re: spark plugs
With stock manifolds, you should be able to get all of the plugs on the passenger side by only removing the alternator and the starter. At least with a single cat car. Thats how I did it way back when.
To do wires on the passenger side, its easier when you unbolt the power steering pump from the accesory bracket so you are able to move it around a bit. Everything else is kinda self explainatory but time consuming.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
