Spark Plug Wires (type)
Old May 1, 2003 | 04:48 PM
GS355's Avatar
What brand do you guys prefer to use with LT headers. I have some Taylor wires but the are arcing and I'm going to make a change.
Thanks GS355
Old May 1, 2003 | 08:19 PM
atljar's Avatar
I had the taylors and had all sorts of issues with them.
I ended up going with the accel 300+ and havent had anything bad to say about them yet. Good wires so far.
Also, you can send the taylor wires back to taylor with a letter explaining the failure, and they will send you a new set. At least they did with me. Then i sold them and almost broke even with the accels.
Old May 1, 2003 | 08:38 PM
BOWTYDE's Avatar
What kind of problem would you have with the Taylors?? I just put some in.
Old May 1, 2003 | 08:50 PM
Bud M's Avatar
If you are going to route them like stock (not over the valve covers) Accel 9000s are good wires.
Old May 1, 2003 | 09:21 PM
atljar's Avatar
arcing, abnormally high resistence, and the rubber coating on them was chipping away. (chunks were missing in different places after 6 months or so).
Old May 1, 2003 | 09:22 PM
BOWTYDE's Avatar
Are you running heards?
Old May 1, 2003 | 09:27 PM
atljar's Avatar
ceramic coated hooker LTs. Had a set go bad in the stock location routing, and switched to OTT wires. Had another set go bad with that routing. Now using the accels in stock location without a problem. These were the 8mm spiro pro. People seem to have better luck with the 10mm race wires from taylor.
Old May 3, 2003 | 11:07 PM
GS355's Avatar
Same problem
Thats the same problem I'm having with my Taylors, but they're not chipping. They are only a month old. I guess I'm going to look into some accel's. Thhanks Guys for your input.
GS355
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
