Spark plug wires too short?
Old May 24, 2006 | 07:46 PM
archangelus2's Avatar
I ordered a set of spark plugs from taylor and they are the same length as a set of taylors that were on the car from a previous owner. Problem is the passenger side ones are too short , I have to route the behind the accessory bracket. Has anyone else had this problems or think that I am doing something wrong. Is there any problem with running them behind the accessory bracket instead of in front of it where the little black holder is?
-Gabriel
Old May 25, 2006 | 10:22 AM
Black_95Formula's Avatar
Re: Spark plug wires too short?
As long as the wires are far enough away from any major heat and/or electrical sources they should be fine. Why not get the Taylor universal kit, that way you can make the wires exactly the length you need.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
