Spark Plug Wires & Tie Straps Question
Old Jun 21, 2003 | 01:45 AM
Smokn '94 Z's Avatar
I heard that it is not good to use tie straps to hold like 2 or more wires together for some reason & that a seperating loom should be used. I guess something with currents..
Any of this true is my question.
Old Jun 21, 2003 | 02:05 AM
Fatdog's Avatar
Cool
I would use some kind of silicone sleeves on the wires where the straps are,like the ones they sell at performance automotive wharehouse or summit,to cut down on resistence.Part #jac400100--You have to just slice them down the middle,and slide them on.Accel makes them,but they want$60.00 or so (fiberglass).These are about $13.00 or so,just use dielectic greese on the inside of them.Hope this helps.
Old Jun 21, 2003 | 02:09 AM
fbird95's Avatar
Some people claim the magnetic field will cause resistance. Not honestly sure if it actually occurs, but anyway, i use the tie straps in place of the stock looms to prevent burnt wires. The stock looms are too close to heat sources for me. I dont tire any wires together, i strap the wires seperatly.
Old Jun 21, 2003 | 02:12 AM
Z-RATED94's Avatar
Yes you do want to keep them seperated. That way if you have questionable wires the spark can't jump from one wire to another and cause a misfire.
Jazsun
Dec 29, 2014 12:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
94z28jbw
Sep 8, 2002 03:22 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
