Fuel injector cleaner: Yes or No?
Old Jun 20, 2003 | 11:35 AM
ibanez6rg's Avatar
I did a search about this and not much came up. Which do you guys recommend? I also read about additives in the cleaners that could cause problems?
Old Jun 20, 2003 | 11:37 AM
IrocManiac's Avatar
I usually get some generic stuff cause they don't load it up with all kinds of cleaners...although I used valvoline last time and it didn't seem to have any negative consequences.
Old Jun 20, 2003 | 11:38 AM
Buttercup's Avatar
Some cleaners do nothing, some cleaners can actually cause damage. The only in-tank cleaner that I might trust would be something like Redline's SR1, although I really don't think it's going to be all that effective. The easiest effective method is to purchase the GM cleaner that is pumped directly into the fuel rail. The best method is to have the injectors removed, inspected, cleaned, and flowed.
These types of injectors are good at self cleaning and aren't really affected by deposits. What can cause problems is particles within the injectors themselves which are unlikely to be simply flushed out.
Old Jun 20, 2003 | 11:39 AM
KCFormula's Avatar
I have heard of them working, however they may gum up the exhaust valve with stuff from the fuel system.
Old Jun 20, 2003 | 11:43 AM
indy500ss's Avatar
I heard the same thing, I have used a cleaner called Berrymans, and I have had no problems at all. I usually throw one in about every 5000 miles or so.
Old Jun 21, 2003 | 02:18 AM
Fatdog's Avatar
Cool
Only if the car isn't running correctly would I recommend any fuel injector cleaner.But the best one is Chevron's techron cleaner.(Costco).If you still have problems,then, you may have other issues.My02(did that stp thing,what a joke).Hope this helps.
Old Jun 21, 2003 | 02:22 AM
chasmanz28's Avatar
good old STP
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
