spark plug wires + lts
Old Apr 28, 2005 | 06:58 PM
DiabloGT's Avatar
im thinking of getting spark plug wires like not the ones on top of the valve covers, but im getting pacesetter lts soon and i heard they melt on them, is that true? is my only choice getting the ones that are on top of valve covers? please help
Old Apr 28, 2005 | 08:41 PM
ABA383's Avatar
Re: spark plug wires + lts
The Taylor OVC from Thunder works great with my 1 3/4" shorties, they should work the same for the LTs. Burnt wires are no longer an issue, and they look great, too. I did mine in black and it almost would pass for stock.
--Alan
Old Apr 28, 2005 | 08:49 PM
MarkyMark's Avatar
Your better off using the OVC setup, but it isnt 100 percent necessary. I know a few people with longtubes that use the stock routing locations. You will just need a bunch of zip ties and a careful routing of all the wires to make sure they dont touch. even then though you are more at risk to burn one, if your worried about the Taylors being hard to make, trust me their not that hard......I got mine done pretty easily and they make my engine bay look badass.
Old Apr 28, 2005 | 09:04 PM
DiabloGT's Avatar
what if i go with afr 210s any time soon what do i do? lol would the ovc work with them?
Old Apr 28, 2005 | 09:17 PM
Don't Look Back's Avatar
I'm had my Pacesetter LT's on for a few months, and I kept stock wire routing. (Besides keeping them in the "track" against the block) Haven't had any problems yet, I just made sure to angle the boots correctly, plus I used the heat shields that are on the stock wires as well as zip ties to keep the wires where I wanted them.
Old Apr 28, 2005 | 09:20 PM
Birdman7389's Avatar
I went with the OTVC setup as well on both my 4thgens. Very happy with the look and performance. One has Jet-Hot LT's, the other Pacesetters, work great on both. Aftermarket heads should not have an affect.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
