Spark plug wires to close together
Is there any truth to having the spark plug wires to close together and causing a miss at upper rpm's due to interference?
I have a weird miss (more like a dead spot) at 5900-6100 and just trying to trouble shoot.
And as always this is an LT1 and it does have a MSD6AL.
Not sure this helps but I've run 150,000 volts threw 4 gauge wire with less insulation and never had the spark come threw the insulation. I think it matters if your wires are old, rotted, or cracked. Maybe someone else who knows more can chime in.
wires that are 2 close together can cause inductive misfire. originally dodge v10's would crack the #7 (iirc)piston due to the fact there were 2 plug wires routed in the loom improperly. this caused an incorrectly timed spark and ka-blooey.
I thought about this but where they run behind the bracket on the pass. side is the hard part.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
