spark plug wire routing
Old May 29, 2005 | 02:24 PM
fearnside5's Avatar
I need a picture of the pass. side routing. Do the wires go around the p/s bracket or through it ?
Old May 29, 2005 | 04:39 PM
salty's Avatar
Re: spark plug wire routing
I just finished routing those wires about an hour ago. Not a fun job. Do you mean stock 7mm wires in in the stock locations? Mine were, and I followed the 4 channels around the big cast metal(grey)bracket that holds up the alternator on the passenger side. It was very tight, and I did one at a time. I removed the alternator, too. I used the stock wire looms except for the one holding #6 & #8 wire together which I broke. I used a zip tie to hold them together, instead.
This is easier if the car is up on ramps so you can get under the car..,
If you don't still have all of the stock clips and channels for routing the wire, maybe you could use zip ties in a few spots? The main thing is to keep the wires away from the manifold/headers(they'll melt) and serpentine belt locations(they'll get torn up).
I'm no expert here, just a few thoughts. I'm so glad to be done w/that job!
Old May 29, 2005 | 04:42 PM
NewbieWar's Avatar
whatever you do dont let them touch those damn pulleys... i've replaced mind 4 or 5 times
Old May 29, 2005 | 11:02 PM
94Z's Avatar
94Z
About 5 years ago, I got some Taylor 8mm wire, made up my own wires and routed everything over the top. Patience, zip ties and some WD-40 helps. Nothing gets close to the headers and 80,000 miles later nothing burnt.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
