spark plug wire order
Old Jun 6, 2005 | 01:44 AM
white93lt1's Avatar
ok so i had a post earlier about me burning my spark plug wires in my 93 lt1....and my buddy was supposed to come over and relocate them.b/c i dont know the order they go....so im getting tired of waiting for him to come over and i want to do it myslef i was wondering if u guys know the order they go on...and i know ur gnna say do it one at a time but we already took some off and my buddy said he may have put some back on wrong....so iw as wondering if u guys could help me with this.. also is there certain routes to go to prevent the wires from gettign burned on the headers
Old Jun 6, 2005 | 01:57 AM
Black1995Z's Avatar
Re: spark plug wire order
cake.... thanks to shoebox
http://shbox.com/1/opti.jpg
As far as Ive noticed Cyl 7 is the only one that you should route a certain way, the rest are self explanitory.
#7 goes againt the block on a groove under the exhaust manifolds, if you look you'll see. Make sure you use one of the longest wires or else you'll end up with a cracked wire in no time.
Old Jun 6, 2005 | 02:02 AM
MaxLean's Avatar
Isn't that interesting, the drawing shows the 'vettes composite valve covers.
Old Jun 6, 2005 | 09:25 AM
white93lt1's Avatar
so would this order not be right???or wiill oit be ok
Old Jun 6, 2005 | 10:42 AM
Alvin@pcmforless.com's Avatar
That order is correct.
Old Jun 6, 2005 | 10:43 AM
sssalah's Avatar
This is the correct firing order which all gen I and II small blocks share.
Old Jun 20, 2005 | 03:29 PM
blind527's Avatar
The wires don't need to be routed a "special" way with OVTC wires right? Just obviously through the valve cover for the drivers side, but what about the passenger side?
Old Jun 20, 2005 | 04:07 PM
Camaro97USAF's Avatar
I routed my OTVC wires on the passenger side down the right side of the valve cover and against the alt bracket. Make sure they;'re zip tied so the don't get fragged by the ps pulley.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
