Spark plug tips are clean to the meatal?
Old Mar 10, 2006 | 02:24 PM
speed_demon24's Avatar
Are the tips of the spark plugs supposed to be clean to the metal? My cars running like ****, missing at part throttle, but it seems to run good once I get past 3/4 throttle. I'm thinkin its my 02's since the computer doesnt use the 02's at WOT. And sometimes the 02's stop cyling for a couple minutes. Any ideas?
Old Mar 10, 2006 | 03:05 PM
GreenDemon's Avatar
Re: Spark plug tips are clean to the meatal?
Are all your spark plugs that way?
Old Mar 10, 2006 | 03:06 PM
I haven't had time to pull them all yet, I just pulled one. It still missing, I switched 02's, and reset the pcm and it started missing as soon as I started it up, so I'm guessing its mechanical, and not a sensor. I'm going to change all the plugs tomarrow and see how they look.
Old Mar 10, 2006 | 03:33 PM
turbo_Z's Avatar
Well if its a true misfire then you can see it if you have a datalogger which Im assuming you do right?
Basically the instant you feel the mis, look at the O2 voltage. Sometimes its not very obvious where other times its very obvious. But what you look for is a lean spot in the reading and if you say they hang up or stop cycling then focus on that. If the voltage is .0xx mV when the sensor stops cycling then thats what bank your misfire is on... so you can narrow the search a little.
Old Mar 10, 2006 | 05:21 PM
LT1 POWR's Avatar
What kind of plugs were you useing and what are you replaceing them with.
Old Mar 10, 2006 | 11:19 PM
I just have a scanmaster. When they stop moving, its both sides. They read between 917-921 basically, and sometimes they don't move for a minute or 2.
Old Mar 10, 2006 | 11:20 PM
They are autolite 106's I'm probably just gonna replace them with 106's again.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
racecarz28
Mar 30, 2015 09:55 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
