spark plug for stroker
Old Jan 24, 2006 | 07:11 PM
T/A Racer's Avatar
okay so right now im using ac delco double platinum plugs. i think they are just the stock heat range or whatever. do i need to switch to a colder plug? will i have detonation problems with an 8.8 DCR and that plug? thanks
Old Jan 24, 2006 | 07:13 PM
Mindgame's Avatar
Re: spark plug for stroker
http://64.65.63.61/forums/showpost.p...18&postcount=8
http://64.65.63.61/forums/showthread...ght=heat+range
-Mindgame
Old Jan 24, 2006 | 07:33 PM
T/A Racer's Avatar
thanks for the links, im probably at close to that +75hp mark with this build. i guess until i get kick *** heads its the torque where my fun will be at. how long would my plugs last if i go to a NGK TR6 those are one heat range colder. assuming no burning plugs and crap like that. if i left the ac delcos in would they most likely burn up then under the higher hp?
Old Jan 25, 2006 | 06:54 AM
badAzz383LT1's Avatar
I put basic AC Delco plugs in and I think they are fouling out bad... She stumbles and idles ruff and im starting to think I also broke one of my injectors from too much of a strain on it. They are 26lb's and with all the HP I have now, might be too much for it.
Old Jan 25, 2006 | 08:43 AM
T/A Racer's Avatar
isnt fouling the result of too cold of a plug? i thought if i used the stock ones they would burn not foul? someone have some advice on here?
Old Jan 25, 2006 | 02:08 PM
T/A Racer's Avatar
Re: spark plug for stroker and head bolts
another question on the head bolts. ive read a ton of forums on here about getting new ones but ive also found some new info that the stock head bolts on a 95 transam are not torque to yield, when i replaced the head gaskets i wasnt supposed to tty either. so why couldnt they be used again? i know this is not what a lot of people do but im trying hard to save some money. i just dont understand why they couldnt be reused if they arent tty?
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
