Spark plug reading guru's within please...
Ok, check em out...
http://www.ufba.org/forum/index.php?topic=6707.0
I think I am too lean, what do you guys think? This was after about 5 minutes of idleing.
The engine is a 1992, 383 with 11:1 compression. SVO 30 lb injectors. What kind of fuel pressure do you guys think I should run
It seems that you're not getting any responces because in order to view the jpg's you posted, we would have to register to be a member of the Utah F-body association.
Maybe this will help you
http://www.gnttype.org/techarea/engine/plugs.html
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
