Spark plug and o2 sensor ?s
Old Jan 14, 2005 | 12:27 AM
AlmostfastLT1's Avatar
I am runing a 11:1 lt1 and runing the tr 55 ngk, what do you think would work best as far as setting the gap on the plug. Also, I installed jet hot longtubes and was wondering where to get o2 extension and what 02 simulater or 02 sensor to buy.
Thanks Guys
Mark
Old Jan 14, 2005 | 09:54 AM
Re: Spark plug and o2 sensor ?s
ttt
Old Jan 14, 2005 | 02:15 PM
Hawk's Avatar
www.thunderracing.com for your 02 extensions and 02 sims
as far as plugs, I would assume it would depend if you have an aftermarket ignition as well. I would think a stock gap with an aftermarket ignition amp would be fine.
Brian
Old Jan 14, 2005 | 08:18 PM
thanks man ttt
Old Jan 14, 2005 | 09:20 PM
Quick96Z's Avatar
i am running close to that compression also, mine are gapped at .035
trav
Old Jan 14, 2005 | 09:27 PM
StickMaster's Avatar
You have a 94, you dont want 02 sims you want new 02s, put them in after you run the new headers for a few hundred miles.
Old Jan 15, 2005 | 10:37 AM
Yea, thanks ttt
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
nikko
Apr 20, 2015 07:56 AM
Jazsun
Dec 29, 2014 12:14 PM
