Spark plug gap putting less stress on ignition system?
Old May 26, 2006 | 02:46 PM
always faster's Avatar
Ok im about to change my plug(tr55) and i already know that the stock gap is .050" .
But...i ve read a couple of time that you can put a smaller gap on the plug to release some "stress" form the ignition system
First is it true?
And if its true can i know why?
What should be the good gap?
And finally does it give the same amount of ignition?
Thank you
Old May 26, 2006 | 10:18 PM
OBE1 95Z28's Avatar
Re: Spark plug gap putting less stress on ignition system?
No need to reduce the gap for a relatively stock engine. This realy only comes to play with high horsepower motors that tend to blow out the spark with the stock gap; usually you narrow the gap to .035" and run an ignition box to boost the spark. I put over 108K miles on my first opti, with 70K of those with an ignition box with no failure. I only replaced the opti because I built a new motor.
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
Ari G
Dec 11, 2014 03:21 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
