Spark blow out? 1/2-throttle performance
Old Dec 17, 2006 | 09:39 PM
  #16
roguedriver's Avatar
If your MAF isn't connected or theres a big leak after the MAF, it probably won't stay running. This is assuming it's not a speed density LT1.
Ken R.
Old Dec 17, 2006 | 09:49 PM
  #17
mrmint69's Avatar
Car is faster at 1/2 throttle than WOT
The car is as fast or faster not pushing it to the max. It is like it bogs if i floor it but accelerate 1/2 to 3/4 it really feels strong. Is there anything i can do.
Old Dec 17, 2006 | 10:02 PM
  #18
BradcTA's Avatar
I've owned a couple of cars that had the same problem and both times it was a clogged fuel filter.
Old Dec 17, 2006 | 10:12 PM
  #19
mrmint69's Avatar
replaced it less than 100 miles ago.
Old Dec 17, 2006 | 10:44 PM
  #20
MeanGreen97Z's Avatar
Could have low cylinder compression at higher RPM.... Bad rings possibly due tot he charger?
Old Dec 17, 2006 | 11:03 PM
  #21
DTC 16 for loss of the Opti low res pulse pattern shuts down the fuel system.
Old Dec 17, 2006 | 11:32 PM
  #22
Is your crank hub keyed? Is it possible the blower drive is causing the hub to slip on the crank nose?
Old Dec 18, 2006 | 06:16 AM
  #23
MEAN LT1's Avatar
Do you have any means of data logging?. This would come in handy for a problem like this. . you could be getting false or real knock therefor the computer could be pulling timing.
Old Dec 18, 2006 | 09:02 AM
  #24
speed_demon24's Avatar
You're probably running out of fuel possibly a bad pump. Did it start when you put the blower on it or did it just recently start?
Old Dec 18, 2006 | 09:16 AM
  #25
mzgp5x's Avatar
My 97 had similar symptoms. I am FI D1 @ 15 psi, and I could feel the power nose over @ WOT high rpm. I installed a HB BAP on the Walbro 255lph pump. Still a power nose over and AFR was lean @ high rpm @ WOT. I installed a 2nd pump (probably over kill) and re-worked all the small diameter short radius stock delivery tube stuff (3/8 Aerquip socketless hose). Problem went away. I really don't think the stock fuel delivery pipe is designed for high volumn flow.
Old Dec 18, 2006 | 03:35 PM
  #26
mrmint69's Avatar
I noticed it after the sc install. I just bought the walbro 255 high volume pump but haven't gotten around to installing it. I had an idea it would solve my problem but everything i have added to the car to make it run better hasn't made much if any of a difference.
Old Dec 18, 2006 | 03:39 PM
  #27
BradcTA's Avatar
100% sure it's a lack of fuel problem. Fix that, fix your problem . You can't run a SC on the stock fuel system
Old Dec 18, 2006 | 05:36 PM
  #28
NJ-LE's Avatar
Question
Sorry ... I missed the part about the fuel pressure loss. I wonder if the PD supplied FMU (or the factory pressure regulator) is working properly or does it suddenly decide to release. What about the EGR. It should be completely closed at full throttle but what if it goes open? What would that do to the manifold pressure signal to the FMUs ?
Old Dec 19, 2006 | 07:47 AM
  #29
MikeTR's Avatar
I had my old Z28 do that when the Cat was going bad....but it only lasted for a few days before it clogged completely. Check the flow out the exhaust, but it's probally a fuel problem.
Peace,
Mike
Old Dec 19, 2006 | 03:08 PM
  #30
Shon Herron's Avatar
Bad gas, run some good gas thru it about 2 tanks worth to get mine cleaned out.
was odd, 100% and it was a dog, let it down to 75% and you would have thought I hit the nitrous, took 2 full tanks to clear it out.
