this sound right?
Old Dec 12, 2006 | 09:59 PM
reamo04's Avatar
this sound right?
well, i wasnt able to find out the cause behind my low RPM miss (misses at 2k), so i took it to the guy that had always done ALL of the work on the car for the most recent owners (owned it from 135k to 145k miles)
well, he gave me a lovely quote
said i need
plugs, plug wires, cap and rotor, fuel filter
i figured the plugs and plug wires, but do i probably need to do the cap and rotor, because i thought when the cap and rotor went out, it caused high RPM misses?
Old Dec 13, 2006 | 05:19 AM
flexus's Avatar
I just replaced my opti whole, my misses were all over the rpm range, including idle. They were even more pronounced while running at low RPM, because they felt worse...
Old Dec 13, 2006 | 12:14 PM
T/A-Bob's Avatar
My bad opti caused misses at low RPMs (1500 - 2500). I think bad ones can cause problems at almost any RPM range.
Old Dec 13, 2006 | 03:17 PM
reamo04's Avatar
yeah, im just gonna replace my cap and rotor
Old Dec 13, 2006 | 03:19 PM
2000GTP's Avatar
You might want to spend the little extra amount and just replace the whole opti since it is accessible anyhow. The cap and rotor aren't the only parts that wear out on the distributors.
Old Dec 13, 2006 | 03:28 PM
mrmint69's Avatar
Check the water pump before you remove anything. I had a problem and it turned out water from the weep hole was getting on the distributor. This is a hugh reason these things go bad so much. I agree in replacing the entire opti espically since you have such high miles. You should be between 3-4 hundred for all the parts minus labor.
Old Dec 13, 2006 | 03:30 PM
reamo04's Avatar
i dont have the extra 200 bucks though, which is my problem
when i do my rebuild next year or so, i will replace the whole opti though
Old Dec 13, 2006 | 03:36 PM
reamo04's Avatar
also, had 2 mechanics check everything, water pump is fine
Old Dec 13, 2006 | 03:39 PM
95LT1conv's Avatar
probably gonna cost almost $150 FOR JUST A CAP AND ROTOR. WHY NOT GET AHOLD OF dAL AND GET TEH WHOLE OPTI FOR A LITTLE OVER $200 TO YOUR DOOR?
Old Dec 13, 2006 | 03:54 PM
reamo04's Avatar
where can i get a whole opti for a little over 200?
all the cap/rotor kits im finding are 100-150 (msd is 150, accel is 100 but out of stock til xmas time), and all the optis are 300-500....
Old Dec 13, 2006 | 04:03 PM
2000GTP's Avatar
Try one of these guys: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Dec 13, 2006 | 04:14 PM
reamo04's Avatar
2000gtp, does it list it on their websites (not finding anything on there) because i looked on the vandevere.com or w/e and it listed firebird ignition distributor for like 375....
do i have to call the number listed/email the guy, or what?
Old Dec 13, 2006 | 04:18 PM
TobyZ28's Avatar
1. Pick up phone
2. Dial
3. ask for Jason / Dal
4. Give car specs
5. Ask for price
6. Buy beer with the $$ u save
You do have a pre 95 non-vented opti which does cost a little more. You may want to consider doing a 95 opti conversion...
Old Dec 13, 2006 | 04:20 PM
reamo04's Avatar
what would all be done in the conversion?
Old Dec 13, 2006 | 04:21 PM
reamo04's Avatar
Originally Posted by toby360
1. Pick up phone
2. Dial
4. Give car specs
5. Ask for price
also, cant do #6, im only 17
just tried calling the dal guy, and no1 answered, any1 know if thats the right number?
