Soon!!!!
Old May 23, 2007 | 09:53 PM
Fastbird93's Avatar
Soon!!!!
The long process is starting to draw to a close. I just got an invoice today for the total price and last payment due on my new motor. Let's just say that motor ALONE has cost me over $12,000.
Splayed 4 Bolt Main LT1 w/Milodon Caps
O-Ringed block
Lunati Sledgehammer Crankshaft
Lunati Pro Mod Billet Rods
custom Diamond dished pistons
LE Ported TFS Heads/LT4 Manifold
BRE Custom Blower Camshaft
Manley 3/8" pushrods
Pro Magnum 1.6 rockers
BBK 58mm TB
The D-1SC kit is sitting right here in the garage. Twin intercooled. Bought with the smaller pulley (Call 911's car has the same specc'ed kit and is making 15# on a similar setup with smaller heads). I'm going to pulley farther if necessary.
The shop that built the motor acquired me a integration harness for the FAST XFI to the 93 so I can keep the computer. The FAST XFI will be one of the last purchases.
Fuel system will be a self made dual in-tank pump setup, stock lines and rails, and mototron 60# injectors to start with.
Provided things go right, I expect to be up and running within 2 months.
Old May 23, 2007 | 10:07 PM
DZNUTTS's Avatar
sounds like fun man.
congratulations.
Old May 23, 2007 | 10:39 PM
My94T/A's Avatar
Congrats man....I am not sure if you remember me, but i m the rutgers student you helped out...way bak wen...but congrats, sounds like you have an awesome setup....
Old May 23, 2007 | 11:24 PM
Fastbird93's Avatar
Sure do man. Finally got rid of the car I see......that's too bad. Good luck finding another!
Old May 23, 2007 | 11:26 PM
SS RRR's Avatar
When I first saw that price I was like
And when I read on that it was a blower car then I was like
Good luck w/ it.
Old May 24, 2007 | 10:59 AM
94Formula/TA's Avatar
good luck buddy! It seems your setup has changed quite a bit since I last saw that car.
Old May 24, 2007 | 12:01 PM
2000GTP's Avatar
Looks like it is going to be a monster.
Old May 24, 2007 | 03:16 PM
Fastbird93's Avatar
Hey man!!! How's the green car treating you, and did you keep the 95???? Yeah, it's changed.....sold the black car last Dec as a roller, this is going into the purple car.
Old May 25, 2007 | 08:39 AM
LT4POWR's Avatar
Good luck w/ it!!!
