Something stopping removal of EGR valve???
Old Oct 2, 2004 | 02:05 PM
CaelanT's Avatar
Angry Something stopping removal of EGR valve???
Tried removing my egr valve today to replace it.
I got the 2 nuts off easily, but there is a pipe below the valve which is preventing removal because it is rotated upwards. I would have to remove the studs from the manifold in order to remove the valve, which would prove troublesome given the location, and probably ruin the threads on them.
You can see it in the pic from shoebox's site here right below the egr valve.
http://shbox.com/1/EGR_pipe.jpg
Anyone able to give me some advice here please?
Took all of 10 mins to remove the nuts. Thought I was gonna be done in 30 mins or so!
94' Z28 Automatic.
Old Oct 2, 2004 | 02:48 PM
Z95m6's Avatar
Re: Something stopping removal of EGR valve???
that is the oil pressure sensor you should be able to rotate it a little bit one way or the other to get the valve out.
Old Oct 2, 2004 | 03:54 PM
Grab the oil pressure sensor near the base and rotate it down just a little, until it is out of the way.
Old Oct 4, 2004 | 11:03 AM
CaelanT's Avatar
Thnx.
I was not sure if this would break if I tried to rotate it, so thought better to ask 1st.
I'll give that a try tonight.
Old Oct 4, 2004 | 04:52 PM
TigerWoodsJr's Avatar
Originally Posted by CaelanT
Thnx.
if you can't rotate it easily by hand use a socket, i forget the size.
HectorM52
Jul 30, 2017 11:46 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
