something is hitting the bottom of my car hard
It will only do it if i floor it off the light i think, i only did it two time then took it home.I will check it after work when there is light out but what could it be, it hits up by where you set at and hits hard to.
iam going to say trans mount i hope .
It could be the torque arm bracket too. The bolt could have come out at the top and the arm is hitting the floorpan. I had this happen when I was breaking in my clutch. Might be worth taking a look at....
I'll vote for tranny mount too, I posted about the same thing last winter and thats about the same set of circumstances. I would definatly go with an energy suspension bit or something, I destroyed my stock replacement in about a month. Seems to be the norm on this board.
sounds like the tranny mount but whatever you do DO NOT BUY THE ENERGY SUSP mount!!! it will cause your drive shaft angle to be too high and vibe!! learn from my mistake. get a 1LE mount from GM.
where can i get one of these mounts, solid or one that will work good, has any one else had the drive shaft problem being to high with the one mount. Do you think it would be cool to drive it easy, it is the mount i checked to day. The rubber part broke right off the metal part. Its kinda cool it happened because i found my bad mis, burnt back plug wire.
thanks
thanks
I had a midget with a hammer under the car as well, and he decides to hit the frame when he is about to fall off under acceleration, or hard downshifts.....
he told me until his replacement can come, he told me to keep the foot off the gas. lol.
but seriously, which tranny mount to go with? and where to get?
