Someone please tell me what this 112lsa means as far as cams go
Old Jun 12, 2003 | 03:27 PM
ONELOUDKAR's Avatar
what is the lsa???
Mike
Old Jun 12, 2003 | 03:34 PM
quicksilver97ta's Avatar
Each lobe has a centerline, its where the lobe is most pointed if you look at it. On a given cylinder, the Lobe Separation Angle is the number of degrees between the intake lobe centerline and the exhaust lobe centerline. Make sense?
Old Jun 12, 2003 | 03:38 PM
StreamlineZ28's Avatar
Lobe separation angle. the LSA is the angle between the intake centerline and the exhaust centerline shown in crankshaft degrees. it shows the overlap between the intake and exhaust valves. smaller the number, more the overlap.
Old Jun 12, 2003 | 03:56 PM
WS6T3RROR's Avatar
just for giggles
overlap = (int duration + exh duration)/2 - (lsa * 2)
also they meantioned centerlines. advance/retard = lsa - intake centerline. for example 112lsa - 108icl = 4 degrees advance ground in. this is the usual case on most lt1 cams because there arent any timing chains that allow you to advance or retard the cam in your lt1 engine. i know those werent your question but they go hand in hand .
Old Jun 12, 2003 | 04:46 PM
ONELOUDKAR's Avatar
thanks
rideordie
Nov 5, 2019 04:52 PM
NewsBot
Mar 19, 2015 12:20 PM
pimpss96
Feb 12, 2015 01:28 PM
NewsBot
Dec 21, 2014 06:55 PM
Wicked
Jul 25, 2002 04:19 PM
