some tranny cooler questions..
Old Sep 23, 2003 | 04:24 AM
  #16
revtime's Avatar
Yours is a little different than mine but if you don,t mind cutting the rubber hose off the top line that goes into the radiator all you will need is clamps and hose.
I cut the rubber off my top hard line with a tubing cutter then I attached the rubber hose and clamped it, now run that hose to the top of the cooler and clamp it.
Now run hose off the bottom of the cooler clamp it and connect it to the open line going back to the tranny. clamp it.
you can get all this stuff at the auto parts or hardware store except for your AN fittings which should have come with the kit.
Thats a mean ***** of a cooler, I looked at that one when I was shopping and decided it was WAY overkill but hey you got the best.
Old Sep 23, 2003 | 01:03 PM
  #17
craigffb's Avatar
Originally posted by madwolf
One last question, I promise.
Did the mounting hardware that came with the kit look like anything you may find at a hardware store or was it something specifically designed for the kit?
The mounting kit is 4 foam rubber squares, to keep the cooler a few inches off the radiator and 4 nylon pins that push through the radiator and have nylon squares with a hole in the center that hold them in place. Kind of like a zip tie that doesn't make a loop if you get my point. You should be able to find something like that somewhere.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
