some throttle body coolany bypass questions
Old Sep 16, 2003 | 12:25 AM
ninetythreez's Avatar
1> does it improve performance or any gains on dyno or track numbers?
2>what is the procedure for doing this on a 93 TB (A4, Z28)
3> i have a BBK 52mm TB on the way. Is it the same procedure?
Thanks for all you guys helping!!!!!!!
Old Sep 16, 2003 | 12:30 AM
CrippleFightin's Avatar
you might get 1-2 hp. but every little bit helps right?
I did it already, but dont remember how....search for TB bypass and I am sure you will find it right away. Not sure about the BBK either...IMO you should have spent the $400 on something else.....exhaust....maybe $100 more and get some LTs....
Old Sep 16, 2003 | 12:33 AM
madwolf's Avatar
Don't know if it improves performance, but I did it only because it makes it so much easier when you need to take out the TB quick to do some work in the area.
FWIW ws6.com claims 6 horses with this mod....
To do it on a 93, you have to disconnect the inlet and outlet hoses from the bottom plate of the TB and connect them together with a copper or brass pipe/connector and some clamps.
Here's a link with pictures and instructions.
The procedure will be the same on the 52mm TB.
Old Sep 16, 2003 | 06:48 PM
$400..not..
I DIDNT PAY $400 FOR THE BBK 52MM TB!! I wouldnt have done that for 400. I paid $210 NEW for it. C.O.D. from a place in Cali.
They were gonna sell me some BBK chrome headers for $225 shipped ..NEW. I found a new honey hole on pricing/mod parts. Maybe we could get up a group purchase and do even better!???
Old Sep 16, 2003 | 09:05 PM
magnumv8's Avatar
just remember to cover your opti before you unhook those coolant lines.
Old Sep 16, 2003 | 09:34 PM
Re: $400..not..
OH! Well then I retract my previous statement!
Old Sep 16, 2003 | 09:41 PM
ibanez6rg's Avatar
Does the system need bleed after this? Coolant left over in the TB?
Old Sep 16, 2003 | 10:27 PM
WheelmanZ28's Avatar
I didn't bleed mine. I just put a towel under the TB outlet for a minute till the last few drops of coolant dripped out.
Old Sep 16, 2003 | 10:31 PM
RamAir95TA's Avatar
Anytime you disconnect a coolant line, you should bleed the system.
HectorM52
Jul 30, 2017 11:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
