Some LT1 Myths/Misconceptions
Old Jul 6, 2003 | 09:42 PM
  #31
CamaroGuy22's Avatar
I am confused about this pcm talk....what do people do like ion or etc when they tune your pcm then? they do normally get hp gains dont they?
Old Jul 6, 2003 | 10:20 PM
  #32
ChickenScreamer94's Avatar
The first concerns plugs and wires. There are no plugs or wires that will add any hp to a stock or mildly modded LT1. So why do some apparently reliable people say they will? Most likely because they are replacing old, malfunctioning parts with new. But the stock parts are fine with stock or mildly modded motors.
OMFG, thank you so much for stating this. I just purchased some autolite wires for my beater, and they were just the same quality as the OEM General Motor wires, if not better. This man speaks the truth! Behold
Old Jul 6, 2003 | 10:32 PM
  #33
Zerocool's Avatar
i am in the process of putting the LT4 hotcam kit in my 94z28 and i was woundering if i needed the LT4 knock moduel to prevent false knock, is this true or do i not need it???
Old Jul 6, 2003 | 10:37 PM
  #34
scoobysnax83's Avatar
Originally posted by revtime
The brake thing again.
WHO CARES!!!!!
If slotted and drilled works for me then just let it go.
Its my money and if I want to waste it then I will (don,t think I am but....)
Mindgame is drag racing Trey, he very well could be seeing a big difference hauling that car down from speed with his "Oh GOD there awful" slotted and drilled rotors.
This is a question of money, period. You say its a waste I say its not.
Could we quit bickering over other peoples money now?
HEE HEE HEE, I love it when brakes come into the picture. Always a great discussion to follow. I'm totally with you revtime. Argue as you all will, but people who think slotted and cross drilled are pretty are gonna say they work better....Its annoying, but sure does get people flamin.....
Old Jul 6, 2003 | 10:51 PM
  #35
Dan K's Avatar
Re: Some LT1 Myths/Misconceptions
Originally posted by rskrause
A related myth is that there are gains from making timing changes. The stock timing is quite agressive and only works because the knock sensor function allows improper operation (low octane fuel, high load at low rpm, etc.) without damage. There will be no gain from advancing the timing on a stock or mildly modded vehcile running on pump fuel.
The stock program is very aggressive. I've always found that by removing timing and brining in your optimum timing as quickly as possible is best...be it 32 or 38 or whatever degrees. Get there as quick as you can and you should be done with it.
I'd like to see some of the more knowledgable ECM guys here get together and write a really short tuning page or slap a sticky at the top of the computer/diagnostics page (and lock it) as a basis to start tuning an LT1 from. Should help those just getting started quite a bit.
Old Jul 6, 2003 | 10:55 PM
  #36
thats a damn good idea!
Old Jul 6, 2003 | 11:03 PM
  #37
xxsaint69x's Avatar
uhhh....so how come my car runs a lot faster with 36 timming at wot instead of the stock 33.5? I only changed the WOT 90-100 kpa...
I guess the timming issue would be true for stock cam cars eh?
Old Jul 6, 2003 | 11:11 PM
  #38
Dan K's Avatar
Heh...yeah...that comment was geared more towards a stock cam. Comparing it to a 306 isn't quite the same.
And where in your stock file did you have 33.5 degrees?
All the ones I have show 35* at 90-95 map and 33 at 100map.
Old Jul 6, 2003 | 11:31 PM
  #39
eagleknight97's Avatar
Alright, im not an expert on brakes or anything, but here goes what I have to say. Brakes are designed to transform forward energy into heat energy. They do this very well by taking the material on your brake pads and pressing the pads onto your rotor. However, after a certain point, the brakes begin to lose effectiveness because after your rotors begin heating up past a certain point, two things happen. #1.) You begin to surpass the effectivness point for which your pads were designed to operate at, and #2.) the extreme heat of the rotors begins to make the pad material glaze over onto the rotor. This greatly reduces the effectiveness of your brakes. Their is also the issue of gas bubbles forming between your pad and rotor due to the extreme heat. A good solution to these problems is cross drilled and slotted rotors. They are much better at dissapating heat, due to their slots and holes, this keeps your pads in their designed heat range and keeps them from glazing onto your rotor. They also totally knock out the gas bubble problem due to the holes. However, the gas bubbles only form in rare occasions and under repeated heavy use. Well, i just thought that i would throw in my .02!
Old Jul 6, 2003 | 11:37 PM
  #40
OMG, If you haven't read the longest post on the board yet (about slotted and cross drilled brakes), then you need to. This post could be useful. If you all would drop the subject about the DAMN brakes....
Old Jul 6, 2003 | 11:39 PM
  #41
xxsaint69x's Avatar
i was just tryin my best to remember what it was stock...btw my car gets 100+ kpa at wot according to datamaster
Old Jul 7, 2003 | 12:03 AM
  #42
Dan K's Avatar
Mine does too.
Old Jul 7, 2003 | 01:09 AM
  #43
brand-x's Avatar
I've been reading the slotted rotor -vs- regular rotors and the slotted rotors should out stop non-slotted rotors. The misconception as I understand it is (scary thought), the slots or drilled holes are not for cooling...they're for relieving pneumatic gas buildups under the pads that prevents the pad from making full contact with the surfae of the rotor...they prevent the traditional cause for brake fade.
Old Jul 7, 2003 | 01:15 AM
  #44
brand-x's Avatar
I've been reading the slotted rotor -vs- regular rotors and I second what I read above.... The misconception as I understand it is (scary thought), the slots or drilled holes are less about cooling and more about relieving pneumatic gas buildups under the pads that prevents the pad from making full contact with the surface of the rotor--they prevent the traditional cause for brake fade.
Old Jul 7, 2003 | 03:49 AM
  #45
rskrause's Avatar
Moderator
Proabably not a bad idea, but even though i had one back before I deactived my KS I havt seen convincing evidence of effectiveness.
Rich Krase
