Some kind of stud where an exhaust manifold bolt should be... maybe???
Old Nov 26, 2005 | 02:07 PM
sabre81's Avatar
I removed my exhaust manifolds & heads and there seems to be a stud on the drivers side head on the exhaust port closest to the firewall. It is not fully screwed in and the top seems to be clean so i dont think a bolt head was broken off... I tryed some vice grips to get it out but it wont budge.
this thing supposed to be there?
Old Nov 26, 2005 | 07:13 PM
96flame's Avatar
Re: Some kind of stud where an exhaust manifold bolt should be... maybe???
Its a busted of stud. Mine was too when I put the headers on but the headers use the other hole so it stayed in there. If you have to get it out you'll need a torch to apply some heat.
Old Nov 26, 2005 | 09:59 PM
OBE1 95Z28's Avatar
You sure you're looking at the driver's side head? The passanger side head has a stud in the exhaust manifold in the front end (towards the radiator) that holds both the exhaust manifold and the alternator bracket.
Old Nov 26, 2005 | 10:02 PM
fesgali's Avatar
I had the same thing on my driver side, i just left it their.
Old Nov 26, 2005 | 10:27 PM
sabre81's Avatar
definitely the drivers side. Thsi stud has no bolt head so i guess ill have have a bolt head welded to it to remove it.
Old Nov 26, 2005 | 10:59 PM
Z95m6's Avatar
it use to be a bolt and it broke off. Don't worry about it if you are adding headers you won't need that hole anymore.
Old Nov 27, 2005 | 11:02 AM
sabre81's Avatar
you sure? here is a picture....
Old Nov 27, 2005 | 11:25 AM
ttop1986's Avatar
yeah u definatly gotta get that one out. they are talking about the hole farthest to the right that doesnt matter. (to the right of the exhaust port)
Old Nov 27, 2005 | 11:31 AM
sabre81's Avatar
thats what i thought. This should be fun.
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
Catmaigne
Dec 25, 2014 12:16 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
