some exhaust questions
Old Jan 9, 2006 | 09:16 AM
snakethis69's Avatar
I recently cut out the old flow master cat back that camr on my 95 because it was a [eice of crap and rusted through the muffler. so now i am without a cat back which isnt that bad in my opinion. i hear about back pressure alot though on the board. i have the current set up. . . two peices of 3" pipe from autozone with a turn down at the axle. my question is should i be looking into a catback to get the most tq/HP out of the LT1 or can i leave it the way it is and still see good gains?
Old Jan 9, 2006 | 09:03 PM
Re: some exhaust questions
ttt
Old Jan 9, 2006 | 09:40 PM
Schweet97Z's Avatar
if it were me i would either go with an actual true dual setup or get another catback....what you have now seems like its jimmy rigged. i know when i went from the loudmouth to the corsa i gained alittle throttle responce and alittle more pep because it finally gave me alittle backpressure. i also know here in PA that you cant get the car inspected if you have anything dumped before the axle. exhuast must go past the axle. if you want my opinion of a catback i would go with hooker or corsa
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
alex5366
Feb 17, 2015 09:07 AM
Chris Anderson
Jan 27, 2015 08:30 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
