Solinoid Trouble
Old Dec 22, 2003 | 04:52 PM
Heatmaker's Avatar
Advanced Member
Solinoid Trouble
Today I Played around with the stick and got the car into reverse then backed it on out. Took it for a few trips around the block. The staging trick really did free up the clutch. Perfect dissengage ment now no more sticking. The only problems I'm having now are with the reverse lockout. I can't get the car into reverse unless the car is shut off. While the car is on Reverse is locked out. I read in one of the old post that someone else had the same problem where they were locked out the R gear with the car on and had to turn off the car and start it in Reverse to go into that gear....exactly how did you fix the problem? Where are the Fuses for the reverse lock out located?
Cars a 95-Z....I understand the Fuses are in different locations or something for different years.
Old Dec 23, 2003 | 12:56 AM
Heatmaker's Avatar
Advanced Member
tippy
Old Dec 23, 2003 | 08:23 AM
SWINGRRR's Avatar
Have you seen this old post?
http://www.camaross.com/forums/showt...5&pagenumber=1
To answer you question, it gets power from the IGN fuse #11 in the udnder hood fuse panel.
I can send you the diagram if you need.
Old Dec 23, 2003 | 04:09 PM
Heatmaker's Avatar
Advanced Member
Ericksd
Jan 20, 2016 06:07 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Schul365
Aug 22, 2015 10:00 AM
Aug 7, 2015 01:26 PM
surreybrad
Jul 5, 2015 10:36 PM
