Solid roller valvespring recommendations?
Old Apr 22, 2003 | 10:40 AM
Mullet Z28's Avatar
Question Solid roller valvespring recommendations?
Need something that handles .675" lift. This car isn't a daily driver, but I would like to get at least 10K miles out of them. The biggest concern is durability.
The Comp 943's look nice, but are kinda pricey. Even more so for some Isky's or PSI's. But unfortunately, money IS an object.
K-Motion are a fraction of a cost of the others, but there have been numerous reports of breakage in the past. Not much feedback recently as far as these issues being resolved though.
Any other options?
Old Apr 22, 2003 | 11:04 AM
BigRick's Avatar
I'm running comp 946's
Old Apr 22, 2003 | 07:16 PM
Mindgame's Avatar
Sorry but valvesprings are one thing you shouldn't skimp on. I've run Comp, Crane, K-Motion and quite a few others but the best I've found for durability and consistency are Isky's toolroom springs. For what you're doing, the 9375/85 Plus or maybe 9385 Plus would be the best bet. Lighter valves... go with the 9375/85.... heavier (Extreme duty type) valves, go with the 9385's. PSI also makes a good spring... well worth the money but I like the Isky lineup for springs.
You'll also get quite a bit more life if you use a valve cover with spring oilers... either that or build some spring oilers. Well worth the effort at this level.
-Mindgame
Old Apr 23, 2003 | 09:39 AM
Mullet Z28's Avatar
Thanks for the help.
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Daluchman1974
Sep 11, 2015 06:12 AM
