solid motor mounts and poly trans mount, OK??
Old Jul 16, 2003 | 04:23 PM
Hawk's Avatar
i read somewhere that if you have solid mounts u need to also upgrade the trans mount. I already bought the solid motor mounts and poly trans mount, is this ok or do i really need a solid trans mount as well??? Anyone running a solid motor/poly trans mount with HEAVY drag racing use?? I plan on juicing a 150 shot out of the hole with a street twin, 12 bolt, and slicks. Thanks.
Old Jul 16, 2003 | 04:26 PM
NVetro's Avatar
Sorry to get off topic, but i cant help look at those pics at your website and they look VERY familiar. I used to live in toms river, hahaha.
scoobysnax83's Avatar
I think you're gonna hate the solid motor mounts and a solid tranny mount would be even worse. Don't take this the wrong way, but what is so serious about you car that you feel you need to run them?
Old Jul 16, 2003 | 04:32 PM
Hawk's Avatar
My passanger side collector hits the frame under load. Also, with the new juice setup i should be around 430hp to the wheels and over 550 torque to the wheels. And i do have a street twin, and will order a 12 bolt, and i have slicks ready for use. Thats why i want to go solid, keep the engine from moving, and i don't care about vibrations as much as strength. Basically i'm at the stage where if i buy something it will be the best of the best for all out power/strength, comfort is secondary. So, as it stands now I think I'll go solid/solid for both, unless the poly trans would be a better choice because it is just as strong and less vibrations?? I actually ordered both mounts, i jsut wanted to know which to install, haha. thanks
Old Jul 16, 2003 | 04:35 PM
Hawk's Avatar
seaside
Old Jul 16, 2003 | 04:44 PM
thats right you're the guy that posted about the engine harness strap thing or something. I forgot about that. What happened to that idea? Seems like it might be something that you could hook up at the track and save yourself from the grief of saturday night cruising.
Anyway, to answer your question. I would think that you would be ok with the poly trans mount simply because the solid motor mounts will be... well solid... So they will be absorbing the torque and not transferring it to the tranny. Make sense? I hope so...
Old Jul 16, 2003 | 04:49 PM
Hawk's Avatar
not really, i would think that if the poly mount gives at all, all the stress will be on the solid motor mounts, the transmission bellhousing, and the output shaft of the tranny. It's like the whole motor/trans is solid in the front, and "loose" in the back and most of the stress will be on the solid mount and the poly will not provide comparable support?? Thats the way i'm thinking about it, correct me if i'm wrong.
As far as the strap idea, i decided against that cuz solid mounts are all around stronger and they are cheap. Also i read up on motor mounts install, and it seems doable and not that much of a hassle. I've installed my entire exhaust system so i think I can handle jackin the motor.
Old Jul 16, 2003 | 04:52 PM
When you put it that way it makes sense. Are we talking about money here? If not then why not just put it in there for safety's sake? Its gonna rattle either way
Old Jul 17, 2003 | 09:40 AM
Toph's Avatar
You should be fine. A friend of mine is running solid motor mounts and a poly trans mount with 740+HP without any problems.
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
x7x7
Aug 15, 2002 06:49 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
