and so it starts...
Old Mar 20, 2004 | 01:39 PM
FormulaLT-1's Avatar
Talking and so it starts...
today is the beginning of a hopefully just under a week project, the parts are in and now I just got to get my lazy *** out there to start...
-35000mile long block
-GM 847 Cam
-Comp non self aligning 1.6's
-K800 springs w/ titanium retainers
-bushings
-Jet hot coated long tubes (still enroute)
-Taylor "over the top" kit
-mezure(sp?) electric water pump
-find a Ypipe
-tuning
I'll try to get a open header sound clip to post up later... I'm sure I'll be posting up questions soon enough.
Old Mar 20, 2004 | 01:46 PM
BTW thanks to Altjar, for the help with part numbers etc.
RedHottG2's Avatar
Good luck with your build up, feel free to fire away with any questions you might have.
Old Mar 20, 2004 | 01:57 PM
ibanez6rg's Avatar
Hopefully I'll be turning the key to mine on Wednesday - Thursday!
Old Mar 20, 2004 | 03:12 PM
how are you liking you jet hots? mine should be here any min.
I didn't know the K800's were double coils, I need to find out if they are supposed to have a pink strip down them, it say K800 on the box but you never know, these things look to big to fit in the stock pocket.
Old Mar 20, 2004 | 03:58 PM
ChevyIron's Avatar
Best of luck to both of you on your cars,Also dont run the car to much with the open headers will cause a rich condition that will cause problems.
Old Mar 20, 2004 | 04:09 PM
just got off the phone with Phil from AI, got some good info, very helpful, I'm looking forward to getting heads already and I still haven't even broken the seal on the new motor.
Old Mar 20, 2004 | 11:23 PM
atljar's Avatar
No problem.
Those springs are double coils, and the paint was a purple/pink color.
They just BARELY fit on the stock seat, but fit. They are a ton bigger than the stockers for sure
Old Mar 21, 2004 | 02:26 PM
time for a quick trip to Reno, to pick up those parts I forgot... how do you forget a YPipe?
Old Mar 21, 2004 | 02:34 PM
schpenxel's Avatar
Mine ran good at first with open headers, then got worse and worse, finally added the Y Pipe and it helped a bunch. THe 02 sensors get confused if theyre close to the open athmosphere, they see lots of oxygen so they add more fuel, not a good thing!
NewbieWar
Jan 6, 2012 06:12 AM
canadianb
Jul 12, 2010 01:51 AM
NuclearZ28
Mar 28, 2010 11:52 PM
ENRKyle20
14
Jul 24, 2009 10:39 PM
