So I just installed my 1LE A/C delete pulley and now....
Old Dec 10, 2006 | 07:37 PM
Huntr1117's Avatar
So I just installed my 1LE A/C delete pulley and now the belt seems to be loose. Right between the alternator and the 1LE pulley the belt kind of wobbles, when the ignition is off it doesn't seem to be as tight as it once was. When my compressor locked up it turned bright orange because it was so hot. Could the heat that the compressor produced when it locked up cause the belt to stretch out? I also heard that some people have to get a shorter belt when they delete the A/C with the pulley. Does anyone have any ideas or part#s for belts that will work? Thanks.
Old Dec 10, 2006 | 08:22 PM
Zeueses 97 RamAir's Avatar
Washer
I think you have to put a washer on the pulley or something to keep it from wobbling...
Old Dec 10, 2006 | 08:47 PM
bingo's Avatar
When I put a 1LE pulley on my car I reused the same belt. Parts stores show two different belts for the LT1. Your car was probably equipped with the longer of the two from the factory. You might want to try the shorter of the belts. If this doesn't work, you might have a failing tensioner.
Old Dec 10, 2006 | 09:00 PM
MeanGreen97Z's Avatar
Some of the delete pulleys are aftermarket ones that make you use a shorter belt.
Old Dec 10, 2006 | 09:16 PM
CALL911's Avatar
When I did the AC delete, and got the delete pulley, I already had an underdrive pulley (currently for sale), + an alternator pulley. That pretty much forced me to get a new belt. It took me forever to find one that fit properly, but I finally got one special ordered through NAPA.
Of coarse then when I put on my ATI super dampner for my supercharger, then I had to get a new sized one all over again.
Old Dec 10, 2006 | 09:20 PM
Huntr1117's Avatar
I got this one from the local GM dealer pn.10115875. I'm just wondering if the heat from the old compressor caused my old belt to stretch out. If that's the case should I just pick up another stock belt and see if it works?
Old Dec 10, 2006 | 09:32 PM
Maybe.... Any good parts store will let you exchange if it doesnt work.
Old Dec 11, 2006 | 12:46 PM
There were two different diameter A/C clutch pullies used on the LT1, so whether or not you can keep your stock belt will depend on which stock clutch pulley you had. Isn't unusual to need a shorter belt.
Is the pulley you installed an OEM GM 1LE unit, or the cheapie they sell on eBay? If its the one from eBay, that might explain the "wobble". You should not have to add any washers to the correct OEM GM part.
Old Dec 11, 2006 | 09:11 PM
Huntr1117's Avatar
The pulley is a OEM GM 1LE unit, it lines up perfectly. It only wobbles because it's too short. I'm just wondering if the heat caused the belt to stretch out. If not what belt part # should I get?
Old Dec 11, 2006 | 09:34 PM
Try an inch shorter belt than stock. See how that works out.
Old Dec 11, 2006 | 10:12 PM
1_badz28's Avatar
i also kept the stock belt but i did'nt change the alternator pulley due to very low amps.
Old Dec 12, 2006 | 11:33 AM
Why the belt is too long is almost immaterial. Check the tensioner pulley. There are indicator marks and a pointer on the housing. If the indicator is not in the correct range, the belt is too long. If its too long, take it to a parts store and get a smaller one. While you are there, compare the worn belt to the stock size and see if its stretched.
Old Dec 12, 2006 | 11:34 AM
What's "too short"?
Old Dec 12, 2006 | 01:16 PM
Huntr1117's Avatar
Sorry Injuneer, I meant to say that the belt was too long. I'll take the belt to the parts store and figure it out. Thanks for everyones help.
Old Dec 12, 2006 | 05:23 PM
gelbza's Avatar
I thought the tensioner pulley was supposed to adjust automatically, thus using the same belt whether the car has A/C or not. I did mine and had no problem with tightness. Maybe the pulley is weak, if that's possible?
