so i have a lifter issue - need advice
Old Jan 10, 2008 | 07:40 PM
Ironxcross's Avatar
apparently i thought it was an exhaust leak but now im pretty sure my lifter is dying or just ticking and making a bunch of noise. what are my options here? should i just buy a cam and new lifters and get a cam swap in the process or should i just switch out the lifters and go from there. i am planning on doing a cam swap down the road but that might be 6+ months down the road. any ideas or suggestions?
Old Jan 10, 2008 | 07:57 PM
bowtiekid's Avatar
Are you sure its a lifter? Take off your intake and make sure, hydraulic roller lifters rarely go bad and are very tough. So before you start assuming make sure its not a loose rocker arm or exhaust leak.
Old Jan 10, 2008 | 08:26 PM
ricehammer's Avatar
Before you go replacing the lifters, try adjusting your valves first. You may just have a rocker nut that has backed off and have a rocker tapping.
If your sure that it's not exhaust and adjusting the valves doesn't fix things, then it's probably a lifter. Since your 1/3 the way there with everything off to swap lifters, I would go ahead and do the cam also. Guess it depends if you can afford the cam, springs, rockers...
Old Jan 10, 2008 | 09:21 PM
guest74777's Avatar
Guest
if you do a swap buy Ls7 lifters, only about 100 dollars and they are good up to 7000rpm in the new zo6's
Old Jan 10, 2008 | 09:49 PM
brubaker's Avatar
Before you go thowing parts and money away buy an automotive stethascope and find the noise. most of them have a removeable end for finding exhaust leaks and other sources of air leakes, if you find no exhaust leaks then pull the valve covers, cut a piece of cardbord to keep oil from making a mess, use the metal rod on your scope on each rocker stud.if one is louder than the rest check ajustment and go from there.
Old Jan 10, 2008 | 10:58 PM
Romero155's Avatar
As stated above i would try readjusting the valves first and seeing if that solves the problem, if it doesnt then you might as well do a cam swap since you will have the intake manifold and you are half way there to it. Look into buying some caddy racing lifters from gmpartsdirect for $100
Old Jan 11, 2008 | 12:27 AM
Ironxcross's Avatar
what would a dead lifter look like? also, theres no drop in performance, just a ticking noise, the car runs just as strong as it always has.
Old Jan 11, 2008 | 12:42 AM
Wild1's Avatar
It could be a sticking valve. I just pulled my heads and could see a tar-like substance in the valve guide that must have leaked past the seal. It was giving me a ticking sound. Especially at low RPMs. It wasn't very Loud, but noticeable.
Old Jan 11, 2008 | 12:45 AM
Ironxcross's Avatar
makes me wonder if i could seafoam it again, but that probably wouldnt work. i dont really want to tear into the motor yet, i dont have the money to start rebuilding parts just yet.
Old Jan 11, 2008 | 06:20 PM
Wild1's Avatar
It may be worth a try. The amount in my guide was very small and smeared to about the size of a dime. But it looked and felt significant enough to cause the valve to stick.
Old Jan 11, 2008 | 06:29 PM
mdenz3's Avatar
FYI, you'll need new pushrods if you do this, the cup in the LS7 lifters is considerably shallower than the stockers.
Old Jan 11, 2008 | 10:35 PM
ricehammer's Avatar
Stock lifters will work just fine. If that is your problem.
Old Jan 18, 2008 | 08:41 PM
guest74777's Avatar
Guest
yea for some motors you will, but with my set-up I had to check for length anyways and ended up needing 7.150's
HectorM52
Jul 30, 2017 11:46 AM
Jun 6, 2015 08:27 AM
jj_burchiel
Mar 5, 2015 07:05 AM
cmyname1
Feb 16, 2015 08:33 PM
David Dorris
Jan 17, 2015 08:10 PM
