So does anyone actaully think this will work?
Old Jan 29, 2004 | 01:47 PM
  #16
Mtrhds94Z's Avatar
Also, [probably too late now, if you started the drilling] another way is to cut in a 'screwdriver slot' with a Dremel tool and then use a hand held[ hit with hammer type] imnpact driver on that..
I have used that method with some sucess also.. works well if it's broken off flush, or just above flush..
Old Jan 29, 2004 | 04:06 PM
  #17
Fastbird93's Avatar
Interesting idea. I like that.
Old Jan 29, 2004 | 04:12 PM
  #18
WS Sick's Avatar
Have you tried heating it up with a torch?
Old Jan 30, 2004 | 12:21 AM
  #19
95BlackTA's Avatar
Dont have a torch. but I like that idea with the Dremel making a flat head end on it. I may see if I can get that to work. We'll see tomorrow if I have time.
Old Jan 30, 2004 | 01:10 AM
  #20
1965GP's Avatar
Duct tape, it'll fix anything....
Old Jan 30, 2004 | 06:12 AM
  #21
Fastbird93's Avatar
If you can use the dremel to make a flathead slot deep enough, use a 3/8" flathead socket, and an adapter with a 1/2" drive ratchet and a breaker bar. Should do the trick.
Old Jan 30, 2004 | 11:09 AM
  #22
Mtrhds94Z's Avatar
I prefer the hand held impact driver[ like 10 bux most places[or less] as it pushes IN and turns it[less likely to strip the slot out]works often tho really..
Red Hawk 94
Mar 18, 2019 04:03 PM
blac94Z
Feb 18, 2015 11:36 AM
squarehead
Jan 15, 2015 07:02 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
