so aggravated
Old Mar 17, 2004 | 09:57 PM
94zLT1's Avatar
so aggravated
doing the tear down for my mac install and damn i cannot budge a single bolt on the y to manifold..i greased em down good to.. any special tool?..hints?..im stuck and cant budge any of these..im having problems with the drivers side y to manifold bolts...i cant even imagine how im gonna get in there on the passenger side..ahhhh..im determined to get at least the y of tonight..
Old Mar 17, 2004 | 10:06 PM
FastZinTennessee's Avatar
Half of the manifold to Y bolts broke on me when I removed them. Just get a breaker bar and break those sumbitches!
Old Mar 17, 2004 | 10:09 PM
97WS6SCharged's Avatar
Impact gun and some extensions.
Old Mar 17, 2004 | 10:16 PM
PatriotTA's Avatar
Half? Ha, you're lucky, all of mine broke!
Old Mar 17, 2004 | 10:28 PM
PB Blaster and some luck. If you are putting headers on, you don't really have to worry about breaking them.
Old Mar 17, 2004 | 10:32 PM
94zLT1's Avatar
im not worried about breaking them...i cant budge a damn one!
Old Mar 17, 2004 | 10:39 PM
You need more power. Give your tools a shot of nitrous.
Breaker bar, deep 6 point socket and whatever extensions you need. Use a cheater pipe for more leverage if you need to.
If all else fails, you may need to get out the flame wrench.
Old Mar 17, 2004 | 10:43 PM
2cub49's Avatar
If you have a set of oxy/acetyline torches and are careful you can heat them up until they're glowing red. Then let them cool down a bit and they'll come loose pretty easy.
Old Mar 17, 2004 | 11:27 PM
1.8ttolt1's Avatar
spray pb blaster liberal, come back ten minutes later and they'll come off.
Old Mar 17, 2004 | 11:34 PM
94zLT1's Avatar
success..well kinda
ahhh beer break...went out there on a mission and managed to hulk off 2 bolts on one side while breaking 15 bloodvessels in my head and arm. only 4 more 2 go...i used a breaker bar on the 2 and the 3rd i cant reach the breaker bar to. how in the HELL am i going to get to the passanger side bolts? i cant even reach my hand in there?
Old Mar 18, 2004 | 12:19 AM
94zLT1's Avatar
the tranny cooler lines and y pipe are in the way of me even gettin 1 hand to the passanger side y to manifold bolts...the only possiblity i have is to weld off the y pipe..honestly how in the hell did you guys with headers get to the passanger side bolts..
Old Mar 18, 2004 | 12:30 AM
I used a torch to take out the old y pipe and all that garbage. Then just unbolted the manifolds and dropped them some to take the bolts out. Then everything kinda fell out with some tugging. That and I have a 6 speed.
Old Mar 18, 2004 | 01:06 AM
Brent94Z's Avatar
Super Moderator
Air tools and a lift
Old Mar 18, 2004 | 01:08 AM
94zLT1's Avatar
what kind of torch and how?
Old Mar 18, 2004 | 01:21 AM
Serene's Avatar
Torch up there sounds like a recipe for disaster. You should be able to break them loose by hand with a bar no problem
