Snapped a bolt trying to remove the cats
Old Aug 23, 2003 | 02:57 AM
CrippleFightin's Avatar
OK I broke a bolt trying to get the cats off for my LT install (Jet-Hot) How am I supposed to get this thing out? I sprayed a ton of Liquid Wrench on all of the bolts and now, after I snapped on, am letting the stuff soke in over night.
I got the alternator off and some off the exhaust manifold bolts off, unbolted the mid section of the Y-pipe and now I need to cut the y-pipe off the exhaust. What should I use to cut it off? I need to get a smooth cut.
Mike
Old Aug 23, 2003 | 09:38 AM
AsianSensation's Avatar
Snapping bolts is a good thing when doing headers. Only place where you don't want to snap one are the manifold bolts. I used a Dremel to cut the Y-pipe off. PITA. Just use a recipricating saw right before the y-pipe meets the I-pipe.
Old Aug 23, 2003 | 10:45 AM
Koby's Avatar
I snapped both of my bolts when I did my cat-back. I just took it to a shop and they heated the bolts up with a torch and then sprayed them off with cold water, then they came right out. Didn't charge me anything either.
Old Aug 23, 2003 | 07:31 PM
OK i am retarded. I didnt even realize I wasnt going to use the bolts ever again......I am slow.
Old Aug 23, 2003 | 07:56 PM
Transamdriver's Avatar
Talking
Bwhahaha I hate when that happens.
maybe2fast
Mar 16, 2015 09:45 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
