snap! timing chain
Old Dec 13, 2003 | 12:54 PM
besz28's Avatar
snap! timing chain
GM OEM Stock Replacement Cam Timing Gear for LT1
GM-10128346 GM OEM Stock Replacement Crank Timing Gear for LT1
hello was reading a post about someone's timing chain snapped he had just replaced the chain,that is what i was going to do,but after reading that i thought better. anyway which of these do i need? cam timing gear or crank timing gear?or both thank you brian
Old Dec 13, 2003 | 02:59 PM
They wear as a set and should be replaced as a set, IMO. Do all three.
Old Dec 13, 2003 | 03:13 PM
BoneStockRacing's Avatar
These is a Lunati set in Summit for 109$.
Old Dec 13, 2003 | 05:08 PM
InjectedSS's Avatar
Does that set still work with the stock waterpump I wonder? If not than it would be a waste of money to get the lunati set when you could get a cloyes double roller set for $80
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
