Smoke coming from tailpipe. Rings or Valveseals?
Old Oct 19, 2005 | 12:49 PM
big dave's Avatar
I just recently had a lean condition while at the track. My fuel pump was on it's way out but did manage to get me home. After the pass at the track, I noticed white smoke coming from the tailpipe.
I pulled a plug and found oil on it. After checking the springs for that cylinder, found that 1 spring on the intake valve and 1 retainer for the exhaust had broken. After pulling the springs, I found that the seals had taken a beating and had to be replaced. After getting everything back together, the car still smoked.
I need to know if I may possibly need to pull the heads to have all the guides and retainers checked or is it possible I wiped out the rings when running lean at the track. How do I troubleshoot this problem?
Old Oct 19, 2005 | 01:20 PM
aintno6's Avatar
Re: Smoke coming from tailpipe. Rings or Valveseals?
There is a chance that the valve it self, or the valve guide could be damaged. Which might be causing the smoke.
But white smoke is normally coolant, and blue smoke is oil.
A leak down test or even a compression test will help you figure out if it is worn/bad rings.
Does it smoke all the time? Or just at start up? Or just at WOT?
Mike
Old Oct 19, 2005 | 02:14 PM
big dave's Avatar
Thanks for the reply. I guess the smoke is kinda blue. It doesn't smoke immediately after startup but after a couple minutes it does. The longer it runs the more it smokes.
Old Oct 19, 2005 | 02:18 PM
Guest47904's Avatar
Guest
Check the PCV system.
Old Oct 19, 2005 | 02:21 PM
aintno6's Avatar
Yea your going to have to, run a compression test, or leak down test on that cylinder.
Mike
Old Oct 20, 2005 | 08:06 PM
big dave's Avatar
The pcv system seems ok. Shouldn't I be seeing smoke coming from the valve cover breather if the rings are gone?
Old Oct 20, 2005 | 09:15 PM
Jazsun's Avatar
If you have real bad rings you will see smoke come out of the dipstick hole for the oil pan while the engine is running due to blowby. Check this, if you see smoke your ****ed.
Old Oct 21, 2005 | 04:22 PM
big dave's Avatar
There doesn't seem to be any smoke coming from the dipstip tube or the breather.
Old Oct 21, 2005 | 04:25 PM
Jazsun's Avatar
prolly valve seals, but it is wierd for a valve seal to cause your car to emit smoke all the way throught the rpm rang when flooring it, usually it will only do it on downreve or intial punch of throttle.
1963SS
Feb 6, 2015 10:05 AM
ChrisFrez
Feb 1, 2015 08:26 AM
Iamherefornow
Jan 26, 2015 04:57 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
