SMOG pass?
Old Jun 18, 2005 | 11:44 PM
BaDBiRD408's Avatar
SMOG pass?
hey guys i am trying to get my car to pass smog.I tried once and it failed don't want to do it again till i know forsure it will pass. i need help reading this scanner?i am getting a high knock sensor about 154 or higher sometimes is that normal and can it affect the emissions to fail smog?i cleaned out my EGR valve and check it with the vacuum see if the valve the diaphram is working ryte and it is.i know that my EGR is working fine it will reduces carbon build up>!My reading with the two oxygen sensor is sometimes abnormal left would be 385 and right would be 689 and sometimes it would be the other way around left side would be higher is that normal?
pls help me give me some guide to check what sensors could be bad thats giving my PCM a bad reading maybe?Or give me any idea what to diagnos for it to pass smog.should i be getting some kind of a percent by the way with the EGR duty cycle coz im getting 0.0% and one time i had 99.4% when i was on the freeway,but everytime im at home car park but on im getting 0.0% on EGR cycle reading??
-here's a list of how my reading's look like-
Desired Idle-650 RPM 01
Engine RPM-750 RPM 02
Coolant Temp-209.7F 03
Manifold Air Temp-86.9F 04
A/C Pressure-105 PSI 05
MAP Sensor-1.43 Volts 06
Throttle Sensor-0.64 Volts 07
Throttle Angle-0% 08
Battery Voltage-12.7 Volts 09
Barometric Press-4.91 Volts 10
Left oxy Sense-457 mVolts 11
Right Oxy Sense-629 mVolts 12
BLK LRN Cell-16 13
Left Block Learn-value 138 14
Right Block Learn-value 120 15
Left Integrator-value 125 16
Right Integrator-value 123 17
Left Inj Pulse-3.6 mS 18
Injector Pulse-3.1 mS 19
Mass Air Flow-7gr/sec 20
CCP Duty Cycle-0.0% 21
Idle Air Mtr Pos-0 steps 22
Learned Idle Pos-32 steps 23
Spark Advance-15*Deg. 24
Knock Retard-0*Deg. 25
Knock Sensor-187 26
EGR Duty cycle-0.0% 27
Vehicle Speed-0 MPH 28
Engine Run time-1083 Seconds 29
A/C clutch-Disabled 30
A/C-Not Requested 31
Park/Neutral-Detected 32
Cruise Control-Not Engaged 33
Brake Depressed-No 34
TCC Status-Not Locked 35
Fan # 1-OFF 36
Fan # 2-OFF 37
Air switch-Solenoid Off 38
Loop Status-Closed 39
Oxygen Sensor-Ready 40
R Rear Oxy Sense-Ready 41
Learn Control-Enable 42
David Dempsey
Mar 12, 2016 12:42 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
