Smell of Gas!
Old Jan 19, 2006 | 12:52 PM
DontMixWithRice's Avatar
Smell of Gas!
Im beating a dead horse here. Im about to delete my damn car.
1995 Camaro RS w/ transplant:
1996 LT1/T-56
1994 Wire harnesses
I have pacesetter long tubes which have causes arching on #5 spark plug wire (driver side 2nd from the top). ALso, i have the Pacesetter y-pipe, no cats, straight pipe to 40 series FLowmaster.
My car sounds and smells like ***. I dont know what the hell is happening.
What shoudl I do? It smells like gas, but big time.
Im going to fix teh wires this weekend, and weld the exhaust everywhere
What else should i do?
Old Jan 19, 2006 | 12:54 PM
Re: Smell of Gas!
also, would it have anything to do with the header gaskets being bad? they were replaced when they were installed.
Old Jan 19, 2006 | 01:23 PM
Re: Smell of Gas!
and finally the evap system:
anyone have links on the entire system, and what needs to be replaced?
i never did it when i dropped in the lt1
Old Jan 19, 2006 | 04:34 PM
Re: Smell of Gas!
There are two things that will cause it to run pig rich....
1. Misfires (sounds lke you have a few misfires from the wires)
2. Exhaust leaks (sounds like you may have a few of those as well)
Shoebox has a diagram of the EVAP system on his website. Let's assume you want the simpler OBD-I setup, without the flow sensor:
Do you still have the canister in the driver's rear fender? I would assume the V6 models must have something similar.
Old Jan 19, 2006 | 06:44 PM
deputydough's Avatar
Re: Smell of Gas!
it took me a week to find why mine smelled like gas. found out my wife ran out of gas(didn't tell me) and bought a small gas can and left it in the car under some stuff. women!!
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
AtlasXVIII
Sep 7, 2015 03:39 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
