Small base circle w/ stroker????
Old May 1, 2007 | 03:45 PM
SS1156's Avatar
I am looking to build a 383 or 396. I bought a cc306 that is not a small base circle. I was wondering if I'm going to have a clearance problem?
Old May 1, 2007 | 03:56 PM
SS MPSTR's Avatar
some rods, yes and others, no.
Old May 1, 2007 | 04:41 PM
Stroker396's Avatar
I ordered mine direct from Comp and the tech told me that if I tried to put a regular cam in my motor that it would get snapped like a twig.
Old May 1, 2007 | 04:48 PM
SS MPSTR's Avatar
hmm. For the last three cams I had, I just ordered small base circle so I didn't have to find out. I understand the rod choice makes a huge difference though.
Old May 1, 2007 | 04:49 PM
mdacton's Avatar
how so?.....I thought all the 306's were on a small circle.
Where would it hit...the shoulder of the head of the bolt?
just curious
Old May 1, 2007 | 07:05 PM
1racerdude's Avatar
A .990 base circle will clear the right stroker rods on a 383. The ones with cap screws not bolts.
Old May 2, 2007 | 06:27 AM
SS1156's Avatar
I was going to run an Eagle rotating assy, most likely a 383. Eagle H-beam rods. I will try to call Comp today, if any one has any 1st hand experience on this let me know.......Thx
Old May 2, 2007 | 06:31 AM
CANTONRACER's Avatar
I run a small base circle cam in my 396" with Lunati 5.850" rods...the rods are not even close to the cam but I had to grind my block big time to get the rods to clear.
Something else to think about...
Old May 2, 2007 | 09:27 AM
SS1156's Avatar
I know I have to have the block clearanced. I was thinking of running 6" rods. I'm wondering if the cam is gonna hit. It sounds like a 396 might be too big for this cam.
Old May 2, 2007 | 11:02 AM
Thy type of rod, not the length will be the determining factor is the rod clears the cam.
I used to run a 388" with the same rod...everything cleared just fine.
Old May 2, 2007 | 11:14 AM
SS1156's Avatar
I was looking to run the Eagle ESP h beam 6" rods. Thanks for everyones help.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Drtryder
Apr 22, 2015 04:17 PM
