Small base circle cam and valve springs?
For those that have or have used a small base circle cam, what are the recommended valve springs to use?
I'm thinking the smaller base circle will make an already aggressive lobe cam even more aggressive requiring stiffer springs due to the circumference around the lobe being less therefore the ramp speed would be even more although the overall lift is still the same.
I'm just trying to figure out why my valve train is so dam noisey compared to others.
I have an LPE211 cam, and have this exact cam just on a regular base circle grind in my truck and its not noisey.
I already have aluminum rockers and composite LT4 covers, but that didn't help, and just swapped heads as well and that didn't help, so now I'm thinking it has to do with the small base circle cam and the beehive springs.
Already swapped lifters too.
Maybe try some dual springs with more pressure.
It used to have a much higher lift cam in it, but had dual springs then, I still have the duals so I may throw them back on there. Truck had duals and it didn't make a peep, went to the beehives on it, and it is a tad bit louder but nothing like the TA. On the TA I swapped the previous cam for the LPE211 and went from the duals to the beehives at the same time and it hasn't been the same since.
oldschool
Feb 9, 2016 09:21 PM
