Is a small base circle cam needed for this 396?
Old May 16, 2006 | 12:33 PM
97bowtie's Avatar
I have been trying to track down this noise for a few weeks now:
http://web.camaross.com/forums/showthread.php?t=444059
The motor is a 396 ci LT1 with 5.850" Eagle H-beam rods, 3.875" stroke and a custom grind cam, with .600/.600 (.375" lobe lift) lift. I've read that Bret uses a .900" base circle cam for all of his cams. If this is the case, is it possible the cam is hitting the rods? I don't *believe* the rods were clearanced for the previous cam (previous cam had .544/.576 lift), and this noise wasn't there before the heads/cam swap. Maybe Bret will chime in.
Old May 16, 2006 | 09:23 PM
97bowtie's Avatar
Re: Is a small base circle cam needed for this 396?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
