SLP vs AS&M need opinion
Old Oct 7, 2003 | 12:31 AM
NiteRider's Avatar
Personally I think i'm going to go AS&M just because of plug access, but SLP's are stainless steel and that just sells it's self. Anyone care to share there own expertise or opinion on this?
Old Oct 7, 2003 | 12:37 AM
Fastbird93's Avatar
You may want to reconsider if you're thinking ASM's have good plug access. It sucks. The headers are OUTSTANDING, but plug access and wire routeing options aren't too great. That said:
ASM's build quality is incredible, and fitment was spot on. You don't have to move the motor at all, which is great for the DIYer. ASM headers are proven to support up to 750 HP, but I'm not sure if the SLP's can support that much. Granted, ASM's are not stainless, but they are coated, and it's a very nice coating at that. Mine would be holding up much better if I didn't ice bag the intake at the track. As for cost, yeah they're expensive, but you get what you pay for.
As for power, I gained 5 mph and .5 in the 1/4 with the ASM and Random Tech Cat Back combo.
Old Oct 7, 2003 | 02:40 AM
NiteRider's Avatar
Thanks, i'm sold, AS&M it is.
Old Oct 7, 2003 | 02:58 AM
5.0THIS's Avatar
Re: SLP vs AS&M need opinion
WHy's that???? just because it's stainless doesnt mean much in this comparison. the AS&Ms have a good coating, so they'll last just as long. and the fitment is waaaay better than SLPs, or so I've heard. I like my AS&Ms
Old Oct 7, 2003 | 05:07 AM
magius231's Avatar
never had a problem with my SLP's, not even a burned plug wire because I was careful in the routing. Since the SLP's are 1 3/4 tubes, they also can support a good deal of HP, and I was able to get a set used for $250.
Old Oct 7, 2003 | 05:09 AM
Fastbird93's Avatar
Yeah, SLP's have their high points too. Intimid8er just went 12.03 BOLT ON with SLP headers. They're good. It's all in what you want.
Old Oct 7, 2003 | 10:41 PM
NiteRider's Avatar
Hmmm.. equally good feedback from both names, i'm still going to go with the AS&M's. Either one of them is going to be a good upgrade from my MAC's.
Old Oct 8, 2003 | 04:31 AM
Fastbird93's Avatar
Why are you feeling it necessary to upgrade from the Macs??? Those shouldn't be holding you back yet.
Old Oct 8, 2003 | 04:43 AM
QCKZ28's Avatar
as&m here, plug access is not the best, the worst being the #2 plug. no burnt wires here, i use msd 8.5, but i dont use any of the stock looms, i route the #5,#7,#8 over the valve covers. and a couple through the motor mount supports, and one behind the power steering pump and i used lots of zip ties
I SHOULD HAVE WENT LONG TUBES.....
Old Oct 8, 2003 | 04:57 AM
Fastbird93's Avatar
Have you dynoed your car?? You look to have a very similar setup to mine, and I'm curious to see what you put down??
Old Oct 8, 2003 | 05:11 AM
magius231's Avatar
your not going to see much difference from the MAC's to any of these headers...IMO your wasting your money upgrading. Put it towards some heads if you want to see a difference.
Keep in mind the fastest bolt on LT1 at the shootout was using Edelbrock shorty headers...
Old Oct 8, 2003 | 05:22 AM
QCKZ28's Avatar
fastbird93 sent you a pm, i didnt want to hijack this thread.
jesse
Old Oct 8, 2003 | 01:37 PM
NiteRider's Avatar
I'm putting on ported heads this winter, there is no way i'm mating them up with MAC's. I'm hoping to put out somewhere near 390 - 400 rw so yes the MAC's woulden't cut it.
Old Oct 8, 2003 | 01:56 PM
drewstealth's Avatar
Hey qckz28 can you pm me your #'s? I'm gonna be going with probably that setup you have except on a m6.
Old Oct 8, 2003 | 02:03 PM
Fastbird93's Avatar
I've got pretty much the same setup. See sig for numbers.
