SLP loudmouth problem
Old Mar 2, 2006 | 09:21 AM
Wicked 97TA's Avatar
Does anyone else have a problem with their SLP loudmouth slipping back off the y-pipe and leaking or is it just me? If its not just me does anyone know a good way to fix it short of welding it up?
Old Mar 2, 2006 | 01:10 PM
95patriotZ's Avatar
Re: SLP loudmouth problem
I havent had any sort of problem like that with mine. Try using a different sort of clamp maybe, otherwise you may be forced the weld it. You could always just tack the pipes in place and use a clamp to seal it still. Good luck
Old Mar 2, 2006 | 07:35 PM
DiabloGT's Avatar
i think i just clamped mine and have no problem?
Old Mar 2, 2006 | 07:47 PM
Steve93Z's Avatar
I noticed leaks with mine, but I bought it used off of eBay (slightly altered). I had mine welded up, ran me $60. Unless you're planning on pulling it off later, I'd have it welded. Just my 2 cents.
Ringmaster72
Apr 2, 2015 08:32 PM
Brake_L8
Jan 20, 2015 09:44 AM
brandboZ28
Jan 31, 2003 06:19 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
jakeSS
Jul 22, 2002 06:54 PM
