slp lm help!!!!!!!!!!!!
Old Apr 2, 2005 | 04:34 PM
DiabloGT's Avatar
i got an slp lm from BadBowtie93Z28 and he cut it on the two points where it goes over the rear axle/past the rear axle and then it skips to the resonator, and i dont know what to do to make the exhaust system work!?
Old Apr 2, 2005 | 04:49 PM
CoUnTryMuZiCZ28's Avatar
Re: slp lm help!!!!!!!!!!!!
Just take it to an exhaust shop.. If your missing a section of the exhaust they should have 3" pipe and they can just weld you on a peice.. Welding would probably be better anyhow..
Old Apr 2, 2005 | 04:51 PM
DiabloGT's Avatar
my uncles can do the welding but like would anyone know of any shop in MA and how much it would cost? and what kind of shape would it have to be? can i just use the stock part and weld it? even though its 1/2 smaller would it work?
Old Apr 2, 2005 | 04:56 PM
if your talking about the pipe. No.. Just go to an exhaust shop and get a peice. Take some measurements then get the right size.. They might not even charge you..
Old Apr 2, 2005 | 05:00 PM
Kataklysm's Avatar
Lous Custom Exhaust has a few locations around the north shore, they charged $100 to take down old catback and weld up a new catback
Old Apr 2, 2005 | 05:06 PM
DiabloGT's Avatar
i dont need them to do that, i can do that, its just i need to know how the hell this will work its like cut off in the wrong spots its like missing about 5" of tubing in a wierd location... i can try to take a pictue but it would take way too long... and where is that s pipe supposed to belong in this?
Old Apr 2, 2005 | 05:09 PM
S pipe goes up front to mount to the cat.. Some years dont need it.. And take a measurement of the length of pipe you need and go to an exhaust shop, buy it. then weld it in place. I believe the cat back is 3"..
Old Apr 2, 2005 | 05:11 PM
DiabloGT's Avatar
is there any way i can post one quick picture on this site so i can show what part was messed up?
p.s. mine is a 95 so it does need an s pipe
Old Apr 2, 2005 | 05:19 PM
You can email me a picture.. CyberSnyper00@aol.com otherwise you would have to host it and post a link
Old Apr 2, 2005 | 05:39 PM
DiabloGT's Avatar
sent it, its a picture of the ad with paint on the part that it got cut on
Old Apr 2, 2005 | 05:48 PM
well.. if that whole section is missing.. you might be able to get an exhaust shop to bend you a peice.. your probably going to have to take the car there for test fitting..
Old Apr 2, 2005 | 06:06 PM
DiabloGT's Avatar
how much would it cost around for that piece? and know the phone # or location of one of the lous custom exhaust shops?
thanks
Old Apr 2, 2005 | 06:50 PM
DiabloGT's Avatar
and CoUnTryMuZiCZ28 can you host that picture so maybe more people can help please?
thanks
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
