slp lm help!!!!!!!!!!!!
i got an slp lm from BadBowtie93Z28 and he cut it on the two points where it goes over the rear axle/past the rear axle and then it skips to the resonator, and i dont know what to do to make the exhaust system work!?
Re: slp lm help!!!!!!!!!!!!
Just take it to an exhaust shop.. If your missing a section of the exhaust they should have 3" pipe and they can just weld you on a peice.. Welding would probably be better anyhow..
my uncles can do the welding but like would anyone know of any shop in MA and how much it would cost? and what kind of shape would it have to be? can i just use the stock part and weld it? even though its 1/2 smaller would it work?
i dont need them to do that, i can do that, its just i need to know how the hell this will work its like cut off in the wrong spots its like missing about 5" of tubing in a wierd location... i can try to take a pictue but it would take way too long... and where is that s pipe supposed to belong in this?
is there any way i can post one quick picture on this site so i can show what part was messed up?
p.s. mine is a 95 so it does need an s pipe
Originally Posted by CoUnTryMuZiCZ28
You can email me a picture.. CyberSnyper00@aol.com otherwise you would have to host it and post a link
well.. if that whole section is missing.. you might be able to get an exhaust shop to bend you a peice.. your probably going to have to take the car there for test fitting..
how much would it cost around for that piece? and know the phone # or location of one of the lous custom exhaust shops?
thanks
thanks
tommalcolm
Sep 11, 2015 03:39 PM
